mopargreg Posted September 18, 2015 Share Posted September 18, 2015 Hi everyone, I'm interested in casting a few small parts for my own use in resin. I don't want use any pressure pots to draw out air bubbles etc. I just want to keep it simple without any setup costs. Can anyone recommend the best product to use for this and the final product won't be full of air bubbles. I read a while ago on the forum someone cast small parts in epoxy. Any ideas on this? I'm no stranger to casting as I have cast my own urethane tires in the past for slotcar racing. Using smooth on silicone for the molds and smooth on urethane for the tires. Quote Link to comment Share on other sites More sharing options...
Kit Basher Posted September 18, 2015 Share Posted September 18, 2015 As long as your molds are properly vented, you should have no problems with bubbles. If you make your molds so they fill from the bottom and vent at the top, the resin will force the air out. Stir your resin mix slowly to avoid adding air. Pour slowly but steadily to avoid trapping air. Both Smooth-On and Alumilite resins will work fine Quote Link to comment Share on other sites More sharing options...
aurfalien Posted September 19, 2015 Share Posted September 19, 2015 Kit Basher hit it on the head.To add, I've chilled my A+B before mixing to slow it down a bit. I also use some talc powder in the mold to help reduce surface tension.I've used a toothpick to force out bubbles as well. Quote Link to comment Share on other sites More sharing options...
Joeys Models Posted September 28, 2015 Share Posted September 28, 2015 If your only going to do just a few castings. Go to Hobby Lobby and get and Aluminlite casting kit. And use the 40% off coupon to save some money. Quote Link to comment Share on other sites More sharing options...
peteski Posted September 29, 2015 Share Posted September 29, 2015 If you have used Smooth-On products to cast your own tires then you know at least the basics of mold making and casting. Smooth-On offers a range of Urethane resins for casting parts and Silicone or Urethane RTV rubbers for making molds. I would stick with Smooth-On and just get what you need. When I need to cast some parts (I use simple 1-piece open molds) I use Smooth-On products. Quote Link to comment Share on other sites More sharing options...
