• Announcements
    • General Usage   05/10/2017
      If someone is acting badly, either in a forum or a private message, please report it. There are conveniently located buttons for sending the post to the moderators.
Sign in to follow this
Followers 0
Gluing parts
3 posts in this topic
At my age, 65, my hands are not quite as steady as they once were. I am currently working on a '58 vette, and the front bumpers are quite smudged with glue.  Does anyone have a solution for gluing small parts together so as not to get globs of glue on everything? I have tried toothpicks, small paint brushes, etc, but none of these seem to do the trick.
Share this post
Link to post
As someone who is two years your senior, I appreciate your problem.  The solution is not a method but a glue.  There are a number of water soluble glues out there that work very well for holding small parts.  Zap Formula 560, Microscale Kristal Klear are just a couple.  These are white glues(PVA) that dry clear but clean up with water.  Just a quick swipe with a wet Qtip and you are done. They are not as quick or as strong as super glues(CA) but will do just fine on bumpers or mirrors.  I like the Formula 560 because it gets tacky very quickly and will hold the part without you having to hold it in place for a long time.  By the way, Formula 560 is often referred to as "canopy glue" as it was formulated for holding R/C aircraft canopies without getting all messy.  Because of this you will have to venture into the R/C section of your hobby store to find it.  My other favorite glue is also in the R/C section.  That is Polyzap.  A nonfogging CA that seems to last a long time without kicking off.  Good luck and I hope this helps.
Edited by Pete J.
Share this post
Link to post
Thanks
Share this post
Link to post
Followers 0
