I've been using smooth-on silicone to make molds for casting hard to find small parts...
does anyone do casting and what do you use...thanks
Share this post
Link to post
what silicone do you use from these companies that are best for parts...
the other thing is that I use 1:1 silicone,it's much easier for me...
Edited by retroguy
Share this post
Link to post
Micro-Mark sells 50:50 two part mold making RTV.  it is easy to mix and sets up well in about 4 hours.  Not cheap but you can get quite a few nice molds from one package.  If you do two part molds you would need to purchase some mold release agent as well.
Share this post
Link to post
Good Sir!
   I am in need of said " silicone to silicone" mold release..... do you have suggestions ....seen a few listed & have been pricey.
Share this post
Link to post
Micro-Mark does have it.  I am not sure if ordinary silicone spray would work or not.  I have not experimented with it.
Share this post
Link to post
I've been making molds for 20 years...I always use petroleum jelly for rubber to rubber release. Never had a problem. All you need is a thin coat!
Share this post
Link to post
I tried the white Smooth-On resin and it worked pretty well, except that both bottles needed to be shaken before use. This gave me a lot of problems with bubbles forming once mixed, and I don't have a pressure pot, so I switched to the Alumilite slow set. So far I have less bubble trouble.
Share this post
Link to post
I've used Smooth On resin for 10 + years. The secrete is to pour parts A & B in their individual containers and wait a bit for the bubbles to go away.  If then  you use a pressure pot, you will get excellent parts. I also use petroleum jelly for a release agent.
Share this post
Link to post
Will coating the part to be casted in WD-40 work?
Share this post
Link to post
Or perhaps cooking spray, such as PAM
Share this post
Link to post
I use Smooth-On and baby powder as a release agent.
Share this post
Link to post
When I was doing All American Models, I simply used Vaseline petroleum jelly, about 1/4 tsp of that to a 4oz jar of ordinary enamel thinner--to coat the cavity and top surface of the first half of my molds, worked EVERY time without fail.  Nowadays, on the rare occasion that I might duplicate a model part for a project, I still use it and it still works.  Very inexpensive too, I might add!
Art
Share this post
Link to post
Alumilite has a 2-part silicone putty that is VERY easy to use. You knead it together, 50-50 by weight or volume, press it over what you want, and it's ready to use in about 15 minutes. You can use only what you need. One pound--a lot of the stuff--is $30 at Hobby Lobby but I've used the 40% off coupon on two boxes of it, which should last me a LONG time. MUCH easier to use than measuring and mixing liquids, and building up dams to pour them, and so forth. Great stuff!
Share this post
Link to post
Polytek Plat-Sil 71-11 silicone & 1512X resin is what I have been using for years. Mold making & casting in a 2 gal. pressure tank, no vacuum or mold release needed. The resin is white, color differences are due to the lighting in the photo.
Resin copy of a scratchbuilt 1949-1950  Merc. door handle fresh from the mold. The aqua colored thing is the mold.
After a little cleanup.
Resin copies of scratchbuilt 1949-1950 Ford interior parts.
After black enamel & Alclad II chrome.alclad1.thumb.jpg.f0b76eebd022ad95f0ad33bab36ef04a.jpg
Resin copies of scratchbuilt flipper hubcaps & 1935 Olds side hood trim.
Castings come out as smooth & glossy as the patterns are.
Steve
Edited by sbk
Share this post
Link to post
21 minutes ago, sbk said:
Polytek Plat-Sil 7 1-11 silicone & 1512X resin is what I have been using for years. Mold making & casting in a 2 gal. pressure tank, no vacuum or mold release needed. The resin is white, color differences are due to the lighting in the photo.
Ah yes. THIS is the kind of quality to strive for. Beautiful work, Steve.  :D
Did you make the masters as well?
Share this post
Link to post
Thanks....it's been a long day. I've been editing this post for the past 15 minutes or so.:blink: Hopefully, the version I saved is correct. Yes, I did the masters on all of these.
Share this post
Link to post
Mold release for making two-piece molds is as close as your medicine cabinet--for over  a decade of commercially casting in resin, making 2-part RTV rubber molds,  the most foolproof mold-making barrier, and the cheapest, which I used exclusively. ordinary Vaseline Petroleum Jelly,  which I added to a 4-oz bottle of ordinary enamel thinner, to make my own mold-release in order to keep the second pour (the inner core of a mold) from adhering to the first (cavity side of the mold) pour.  Worked without fail every time.
Art
Share this post
Link to post
