Sign in to follow this
Brandon Miller
Wheel, hub, brake detail
So here's my wheel and brake set I was waiting on to arrive. You will be able to see the detail better once I get some paint on it. This set is going on a 2018 F150 diecast. The hubs may need to be adjusted slightly for the Gen 6 kits. I will get that figured out in the next night or two. The rotors and calipers are Nascar units and everything fits inside the rim. The rotor and wheel slide over the lugs on the hub. Once the lugnuts are separated from the tree and drilled out with a #70 drill, they will slide over the lugs as well and will be glued in place.
Share this post
Link to post
