fiatboy
preparing resin parts: soak in Simple Green?
Can resin parts be briefly soaked in Simple Green, and then primed with laquer primer?  Thanks
Share this post
Link to post
You should be ok. I don't think it is as strong as Super Clean, which some casters recommend.
Share this post
Link to post
Why do they need soaking?
If you are removing mold release agents, you could try something more benign like Bleche White.
Or many people claim that soap and water will do the trick.
Steve
Share this post
Link to post
While we're on the topic, does Super Clean hurt resin?
Share this post
Link to post
Some 100% first-hand experience would be nice.
Resin kits can easily cost upwards of $200.
That's not a sum I'd like to risk on "I think" or "I've heard".
Share this post
Link to post
I personally have soaked resin bodies from Modelhaus in Super Clean, but not for an extended period of time.
I have not had any issues.
This is a paragraph from an old Modelhaus catalog from 30 years ago.
I would hope that this might possibly put this question to rest.
If it was good enough for Modelhaus for all of these years............
This is as close to 100% as you're going to get.
This is not to say that all resins are the same.
Steve
Edited by StevenGuthmiller
Share this post
Link to post
I have always just soaked the parts in some water with a little dish soap for 3-4 hours, never have had any issues.
Share this post
Link to post
Spraying the parts with Clorox All Purpose Cleaner, and a little scrubbing with a toothbrush, works as well.
Share this post
Link to post
I've only done one resin model and used Westleys Blech white (yea that is the correct spelling)  and had no issues.  It was a very large casting, 14" wing span and 12" long fuselage, all one piece.  Soaked it over night, too a toothbrush to it to get in the panel lines and then hit it with Tamiya white primer.  Primer went down like a dream.  Smooth and even, no fisheyes.
Edited by Pete J.
Share this post
Link to post
No matter what works for you in cleaning resin parts, it's been my experience that lacquer primer doesn't bond well to resin unless it's been abraded somewhat.
I use Comet cleanser, a bit of warm water and an old toothbrush to scrub the parts before putting on ANY primer coats.
Share this post
Link to post
3 hours ago, stinkybritches said:
This is what is recommended on the Jimmy Flintstone website:
  1. CLEANING – Before using, parts must be washed off with soap (Westleys white wall cleaner), and alcohol to remove mold release.
http://jimmyflintstonestudios.com/?page_id=41
Only problem with that is that Westley's is now a "new and improved" product from a company called Black Magic, and "new and improved" almost always means "environmentally friendly, and all the stuff that used to actually make it WORK has been removed...and replaced with water because it's cheap".
MANY online car guys say the new stuff doesn't work like the old stuff. I've used it on tires myself, and it's next to useless...where the old stuff made 'em look like new.
Any input on this?
Share this post
Link to post
I've only used old-formula Bleche White. It worked great. Used lacquer primer and paint with no problems. I still have my bottle. Guess I'd better keep a close eye on it. I have a $350 kit I want to come out perfectly.
Share this post
Link to post
As referenced above, it looks like Bleche Wite is pretty crappy now. I have a Jimmy Flintstone 1961 Ford Starliner body that I am eventually going to do something with and I see a lot of recommendations for warm soapy water and alcohol. Whenever I get to it I will probably follow the procedure from this web page:  http://www.resinparts.com/working-with-resin.html
Share this post
Link to post
Any input on this?
The bigger the skull and crossbones on the package, the better it works...
Share this post
Link to post
Pretty much always the case, unfortunately. My '89 GMC truck with the more "environmentally friendly" water-based paint that's almost entirely self-stripped is a shining example, while the first-generation wildly toxic urethane I shot a VW doublecab pickup with in 1984, that's lived outside all its life, still polishes up to look almost new.
Share this post
Link to post
Thanks everyone for the responses.
Share this post
Link to post
I have used Simple Green as a cleaner for resin parts and bodies for a number of years with no problems. I also soke white metal and PE in to get rid of any casting residue.
Share this post
Link to post
