Hws5283 Posted January 13, 2021 Share Posted January 13, 2021 I realize plastic cement is meant to bond plastic on plastic so how should you glue together parts that are already painted? Ive heard people say to just scrap the paint off on areas to be bonded which im not completely opposed to but are their any other ways which are better ? Quote Link to comment Share on other sites More sharing options...
espo Posted January 13, 2021 Share Posted January 13, 2021 Depending on the type of glue or bonding agent you use the parts will usually hold OK. But the best results will involve bare plastic against bare plastic where the two parts meet. This should be done with small enough mounting surfaces wouldn't be seen anyway Quote Link to comment Share on other sites More sharing options...
mattg Posted January 13, 2021 Share Posted January 13, 2021 You can use CA glue or Epoxy, but whatever you use, the bond will only be as strong as the bond between the paint and the plastic. Quote Link to comment Share on other sites More sharing options...
Erik Smith Posted January 13, 2021 Share Posted January 13, 2021 Super glue or epoxy or Future or...any glue or glue type substance that does not rely on melting the plastic. Quote Link to comment Share on other sites More sharing options...
Ace-Garageguy Posted January 13, 2021 Share Posted January 13, 2021 11 minutes ago, mattg said: You can use CA glue or Epoxy, but whatever you use, the bond will only be as strong as the bond between the paint and the plastic. Correct. And amazingly, this common-sense idea is routinely overlooked by lotsa folks who should know better. Better by far to pin small parts. Quote Link to comment Share on other sites More sharing options...
Oldcarfan27 Posted January 14, 2021 Share Posted January 14, 2021 I usually build like color sub-assemblies before painting anything (engine/trans with painted valve covers, manifolds, fuel pumps, oil filters, etc.) or (chassis, suspension, subframes, mounts - sometimes radiator core supports) (bodies with bumpers, front grille areas and rear tailpans) Then I can paint it all at once and minimize messy glue joints for the major parts. I find that detail painting the small glued-on parts easier than trying to glue them on after they've been painted. Quote Link to comment Share on other sites More sharing options...
