Zippi Posted October 27, 2022 Share Posted October 27, 2022 (edited) I don't know how many times I have completed a model to the point where it's time to fit the interior tube into the body and it doesn't fit. For me it's always the windshield or dash that is the issue. I hate tearing things back apart. How do you fellows trial fit the interior tub to the windshield prior to glueing? Edited October 27, 2022 by Zippi Quote Link to comment Share on other sites More sharing options...
Bainford Posted October 27, 2022 Share Posted October 27, 2022 (edited) For a windshield, I would use masking tape to secure it to the body. I'm big on mock-ups. By the time I finish a model, much of it has been together and apart again dozens of times. It goes a long way to reducing the number of issues at final assembly, though I must say, it does not eliminate them. There is almost always something significant that goes together very well in a mock-up but, maddingly, still doesn't want to fit smoothly at final assembly. Sometimes I wonder if I would be better off not doing frequent mock-ups... at least there would be an excuse for things not fitting at final assembly. Edited October 27, 2022 by Bainford Quote Link to comment Share on other sites More sharing options...
Plowboy Posted October 27, 2022 Share Posted October 27, 2022 One thing I do on the windshield is test fit first and if there anything hanging below the bottom of the cowl, I trim it down until it is flush. Same for the backlight. Then put the interior together temporarily and test fit. 1 Quote Link to comment Share on other sites More sharing options...
Zippi Posted October 27, 2022 Author Share Posted October 27, 2022 1 hour ago, Bainford said: For a windshield, I would use masking tape to secure it to the body. I'm big on mock-ups. By the time I finish a model, much of it has been together and apart again dozens of times. It goes a long way to reducing the number of issues at final assembly, though I must say, it does not eliminate them. There is almost always something significant that goes together very well in a mock-up but, maddingly, still doesn't want to fit smoothly at final assembly. Sometimes I wonder if I would be better off not doing frequent mock-ups... at least there would be an excuse for things not fitting at final assembly. 2 minutes ago, Plowboy said: One thing I do on the windshield is test fit first and if there anything hanging below the bottom of the cowl, I trim it down until it is flush. Same for the backlight. Then put the interior together temporarily and test fit. Thank's for the info Trevor and Roger. Quote Link to comment Share on other sites More sharing options...
Exotics_Builder Posted October 27, 2022 Share Posted October 27, 2022 1 hour ago, Plowboy said: One thing I do on the windshield is test fit first and if there anything hanging below the bottom of the cowl, I trim it down until it is flush. Same for the backlight. Then put the interior together temporarily and test fit. Ditto 1 Quote Link to comment Share on other sites More sharing options...
StevenGuthmiller Posted October 27, 2022 Share Posted October 27, 2022 4 hours ago, Bainford said: I'm big on mock-ups. By the time I finish a model, much of it has been together and apart again dozens of times. There you go. Steve Quote Link to comment Share on other sites More sharing options...
Zippi Posted October 27, 2022 Author Share Posted October 27, 2022 57 minutes ago, StevenGuthmiller said: There you go. Steve Thanks fellows. Quote Link to comment Share on other sites More sharing options...
Bucky Posted October 27, 2022 Share Posted October 27, 2022 Another thing to consider is doing a test fit after you have everything painted a final time. It's amazing how the thickness of paint can alter how things fit together. 3 Quote Link to comment Share on other sites More sharing options...
StevenGuthmiller Posted October 27, 2022 Share Posted October 27, 2022 1 hour ago, Bucky said: Another thing to consider is doing a test fit after you have everything painted a final time. It's amazing how the thickness of paint can alter how things fit together. Absolutely. This is the biggest issue with fitment that I run into with my projects. I have a habit of being too precise with fit during the engineering phase, and with the addition of paint, it can occasionally become a problem later. Steve Quote Link to comment Share on other sites More sharing options...
Zippi Posted October 27, 2022 Author Share Posted October 27, 2022 5 hours ago, Bucky said: Another thing to consider is doing a test fit after you have everything painted a final time. It's amazing how the thickness of paint can alter how things fit together. Thanks Keith. Quote Link to comment Share on other sites More sharing options...
Zippi Posted October 27, 2022 Author Share Posted October 27, 2022 4 hours ago, StevenGuthmiller said: Absolutely. This is the biggest issue with fitment that I run into with my projects. I have a habit of being too precise with fit during the engineering phase, and with the addition of paint, it can occasionally become a problem later. Steve 👍👍 Quote Link to comment Share on other sites More sharing options...
espo Posted October 28, 2022 Share Posted October 28, 2022 As others have pointed out, a trial fit in advance of any gluing or painting can show fitment issues. I have found it amazing how just a little minor fit issue with the interior sides and dash become huge problems when you try and fit the interior into the body and the glass. A little adjustment and sanding ahead of time can save you more time than you realize. Quote Link to comment Share on other sites More sharing options...
Kit Karson Posted October 28, 2022 Share Posted October 28, 2022 Consider a final mockup (or at any stage along the way) temporarily assembled using water-soluble white glue. Some have said RC56 works quite well but may take a bit longer to dissolve. -KK Quote Link to comment Share on other sites More sharing options...
drifterdon Posted November 1, 2022 Share Posted November 1, 2022 On 10/27/2022 at 1:25 PM, StevenGuthmiller said: Absolutely. This is the biggest issue with fitment that I run into with my projects. I have a habit of being too precise with fit during the engineering phase, and with the addition of paint, it can occasionally become a problem later. Steve I realize the OP is talking about interiour tubs but Steve's comment here is especially true when it comes to hoods fitting. Quote Link to comment Share on other sites More sharing options...
Zippi Posted November 2, 2022 Author Share Posted November 2, 2022 On 10/28/2022 at 10:56 AM, espo said: As others have pointed out, a trial fit in advance of any gluing or painting can show fitment issues. I have found it amazing how just a little minor fit issue with the interior sides and dash become huge problems when you try and fit the interior into the body and the glass. A little adjustment and sanding ahead of time can save you more time than you realize. Thanks for the info. Quote Link to comment Share on other sites More sharing options...
Zippi Posted November 2, 2022 Author Share Posted November 2, 2022 On 10/28/2022 at 12:34 PM, Kit Karson said: Consider a final mockup (or at any stage along the way) temporarily assembled using water-soluble white glue. Some have said RC56 works quite well but may take a bit longer to dissolve. -KK I appreciate the tip. Quote Link to comment Share on other sites More sharing options...
Zippi Posted November 2, 2022 Author Share Posted November 2, 2022 3 hours ago, drifterdon said: I realize the OP is talking about interiour tubs but Steve's comment here is especially true when it comes to hoods fitting. 👍 Quote Link to comment Share on other sites More sharing options...
