• Announcements
Sign in to follow this
Followers 0
How to make a reallistic sliding side door on a Ford "Phantom" Van?
6 posts in this topic
Picture how to to requested.
Share this post
Link to post
That would take some pretty slick micro-engineering and I kinda doubt anyone's done it yet. You can probably be the first with a really trick mod.
If you look at 1:1 sliding van doors, you'll see there are curved tracks in the body shell, and support arms from the doors that have rollers on the ends that run in the tracks.
To make a scale, working version, you're going to have to duplicate the motion provided by the track-and-roller arangement, in whatever scale you're working in.
There's no easy way....this will require some carefully measured, thought out and fabricated work....and even a tutorial won't show exactly what measurements you're going to need for your particular application. Study the full-sized ones and go from there.
Good luck with it, and if you get it done I'm sure we'd all love to see your results.
Share this post
Link to post
Sounds like a tough job. I would love to see it if you can pull it off.
Share this post
Link to post
Give Bill Geary some time to work on it, and I'm sure he'd be able to do it..... Just look at all the other working stuff he's come up with... The man is a BEAST......
Share this post
Link to post
Steve Perry's ALREADY done it. His Ford 4x4 van and Drag jet-drive boat took first in his class I believe(though i'm not sure)at GSL. It has a completely functioning slideing side door that id prototypicaly correct. Steve's a good freind and fellow member of the DMCC. A nicer guy you'll NEVER meet!
Share this post
Link to post
Bill can do it
Share this post
Link to post
Followers 0
