Search the Community
Showing results for tags 'fire engine'.
  • Search By Tags
  • Search By Author
  • General
    • Welcome! Introduce Yourself
    • Tips, Tricks, and Tutorials
  • On the Workbench
    • WIP: Model Cars
    • WIP: Drag Racing Models
    • WIP: Dioramas
  • Under Glass
    • Model Cars
    • Drag Racing
    • Dioramas
  • Industry Corner
    • Car Kit News & Reviews
    • Truck Kit News & Reviews
  • Marketplace (No selling)
    • Trading Post
    • Wanted!
  • The Community
    • Contests and Shows
    • Community Builds
    • Auto Art
    • Where's Waldo?
    • Diecast Corner
    • Model Car Racing
    • The Off-Topic Lounge
Find results in...
Find results that contain...
Date Created
  • Start
    End
Last Updated
  • Start
    End
Filter by number of...
  • Start
    End
Group
Website URL
Yahoo
Skype
Facebook
Full Name
Are You Human?
Scale I Build
Found 1 result
  1. A long time ago I started to combine a Revell Snap Peterbilt 359 kit with the rear body of a Trumpeter American LaFrance pumper. My goal was to make a "short" conventional pumper using the forward rear suspension location on the Peterbilt and mock up a new, smaller pump panel. This is how the idea looked when I mocked it up a few years ago. After a few moves and some more thought, I started to get this one going again. The rear of the cab wall was fixed, the passenger side battery box was removed and a fuel tank from the AMT Peterbilt 359 wrecker was mounted there instead. The chassis was modified simply to remove the driver side stack, which required filling of those mounting holes on the cab. Then came the paint, white with red accents. Of course, after I painted the chassis and began assembly, I realized that I wanted to add a pseudo pump, and had to add that before installing the drive train. Don't look too closely, you wont see u-bolts where the pump connects to the shafts...I forgot about that. The front bumper was modified to store rolled hose, but a front mounted intake just doesn't work with this particular cab design. I'll have to convert it to a small trash line. And here's the mock up with the pumper body and pump panel. Both side intakes will have rolled hose, the officer's side will be connect, but the driver's side will not be. I did open up the grill on the snap kit, but I cheated and cut off the vertical supports. I used half round to put them back in and give the black mesh ribbon something to mount to. The bumper currently isn't attached, I had to make additional arms so that it would mount to the frame properly. I also drilled out the lights in the bumper and added sirens from the 1/32 Mack pumper kit. Regular strobe lights will be added later on in assembly. I did modify the pumper body slightly. I’m building this truck for a volunteer fire department, so water quantity is a strong requirement. The College Park ALF pumper is only designed to carry 500 gallons, I wanted 1000 gallons, but I settled for 750 gallons by raising the hose bed and replacing the back panel with diamond plate, a couple of steps, and two non-functional doors. I could have gone for more water storage, but I would have just built a new, longer body instead of recycling this one. Hopefully tomorrow I can get the body and pump panel into some primer, this humidity isn't real nice for painting this rig right now. Once everything is painted, I'll start placing the decals, make the hose load, then add all of the other little details to finish this one out. I do apologize in advance for the poor picture quality. Let me know what you think.
