Stang Assembler Posted June 12, 2016 Posted June 12, 2016 Ok, Could use some tips on how fill the gap between the body and interior tub. When test fitting them together there is a nice gap there. Was thinging on cutting a piece of clear plastic to put there to look like window. Maybe cutting doors out body and tub to hinge them( but I'm not that skilled modeling). Will post a pic later on the to show problem when batts for camera r charge up. But ne tip from all are welcome.
Yenkocamaro Posted June 12, 2016 Posted June 12, 2016 Check out Evergreen plastic products. They make all kinds of shapes, but for your problem, I would go with plastic strips, that come in a variety of width's, and thicknesses. Split the gap you have in 2, to keep the interior tub centered, cut to the size you need for each side, and glue in place, to the interior outer side panels. I would recommend a liquid cement for this. Are you sure this is the right interior? was this a brand new kit? Not sure if this is a common problem with this kit. I'm sure others who are familiar, will chime in. Cheers,Lance
Stang Assembler Posted June 12, 2016 Author Posted June 12, 2016 I purchase this kit around 1998 to 2000. Start it back then and put it down. Put all piece in the kit box set on shelf for years. Now just getting back in to it. I did buy a newer box kit of same kit. Guess I could see if that interior tub from it fits better. TY
