Hey guys,
Like the title says I need help, I received my order from KFS that incl.
the Hendricks & the BPW lift axle.
How far from the first tandon do they go or, does it depend on the owner of
the truck
Thanks for the help
J Smith
on a real truck it depends on where the load is to be carried,how many drop axles you have,and where truck mounted accessaries are located. so for your model do what looks good.i mounted my last one the same distance in front of the fist tandam as the distance between the first and second tandam axle.
Hi:
I've actually studied this topic quite a bit, so I thought I'd chime in here. In the US, any group of axles spaced 96-inches or less is considered a tandem, so if your drive axles are spaced 54" apart, you'd want to put the pusher axle at least 42" ahead of the forward drive axle. I see a lot at 43" giving an extra inch to be sure the spacing is at least 96".
Here in Minnesota, many pusher axles on tri-axle trucks are placed 55" or 56" ahead of the forward drive axle due to a state statute that says any axle in a tridem spaced 9-feet or less may carry no more than 15,000 pounds. Making the tridem measure 9'-1" ensures the two drive axles can still carry a total of 34,000 pounds.
Quad-axle, quint-axle, and superdumps (sadly, we have only a few of those here) generally have the pusher axles spaced close together to make use of limited frame space. Any group of axles spaced 40-inches or less is considered a single axle, so pushers on multiple lift-axle equipped trucks generally have the first pusher at least 43 inches from the first drive axle (see first paragraph) and successive pushers spaced 40.5", or 41" apart. This is, however, not universal. I've seen quad-axle dumps with their pushers spaced further apart to ensure the steer axle isn't overloaded.
If you wanted to build a super dump, you'd probably want to shove the pusher axle as far forward as possible as the booster axle really loads up a steer axle. However, if you wanted to build a boost-a-load mixer, the pusher axle could remain close to the drive axles as the mixer drum locates the load in a consistent position whereas on a dump it's more variable. Heavy-haul tractors typically seem to have the pusher axle spaced similar to the that between drive axles, or about 54" ahead of the forward drive axle.
This may be more than you were looking for, but I find the whole weight-distribution exercise quite interesting. It's part of the reason I left a job of 17 years to become a full-time mechanical engineering student.
Bryan
