I am having great difficulty in putting the body and chasis together in the final assembly. Is there any tip or trick that I ought to know to make the final assembly possible? Thanks!
Along that thought, you might need to elongate the mounting hole front to back a bit to get the pin behind the backlight to properly fit the interior tub in. I had to on my Yenko Camaro, but didn't have to on my Z-28.
IIRC, (I built both cars several years ago), it was easier for me to fit the chassis in place front end first, & then work it into place from there. I also left off attaching the wheels/tires until after the chassis was in place.
Hope these tips help!
:lol:
Thanks for everyone's pointers. I was able to fit the chasis and body together. I learnt doing it by opening up a new Z/28 kit and tried fitting the chasis and body together. I found that I needed to squeeze the front wheel wells to flex the chasis into the front part of the body first before I worked the rear part. So I went back to my painted kit and removed the front wheels before attempting to fit again. I am glad I did not have to give up on this almost finished kit.
