Patrick2005 Posted February 7, 2011 Posted February 7, 2011 Can someone tell me how to to make the colors for a 64 Pontiac and 69 AMX?
SteveG Posted February 7, 2011 Posted February 7, 2011 All Pontiac V8 engines from 59-65 were a Sky Blue. The photo is of freshly rebuilt '62 421 for reference. It's pretty easy to mix up your own match from hobby paints. You can also order a lifetime supply by buying a spray can of actual engine enamel from Classic Industries, Summit or any similar outlet. I'm no expert on AMC engines but I think the '69 390's were a Metallic Blue. Hopefully someone who know for sure will jump in with more info. -Steve
MrObsessive Posted February 7, 2011 Posted February 7, 2011 Right Steve.............AMC 390's were a bit of a metallic blue with a very slight hint of green------the exact name was called "Alamosa Aqua". My 1:1 '69 AMX's engine was painted in that color. Here are a couple pics out of a restored car.............. This shouldn't be too hard to mix manually.............some dark blue and a touch of green, and some aluminum to mix. Just keep adding the aluminum to the blue/green til you get it.
Patrick2005 Posted February 7, 2011 Author Posted February 7, 2011 thanks a lot guys, this shouldn't be too hard......even for me!
tim boyd Posted February 7, 2011 Posted February 7, 2011 For the early 1960's Pontiac Engines, the Tamiya Sprayc color, i believe it is called "coral Blue", is to my eye a near exact match. For the AMC engine, you can try custom mixing the color, but for the best accuracy, i recommend purchasing a can of AMC Engine Blue spray paint. It will last you probably for the rest of tyour life, and can be mail-ordered abnd arrive at your door for most likely less than $15 in just a few days. I also recoommend 1.1 scale engine paint for the Silver Blue metallic color for mid-1960's to early 1970's Pontiacs, as Testor's Pontiac Engine blue brush paint is too silver./not enough blue for my taste. TIM
Longbox55 Posted February 8, 2011 Posted February 8, 2011 Testors Model Master Interior Metallic Blue from their military line is pretty close to the AMC color, too.
