Can anyone help me out, I've been looking at images on google to fins out where the distributor is for the HT cables on this engine, it's the Ferrari 360 from Tamiya, I ust can't see it, I've scanned the engine shots here, please help me out!
The Ferrari 360 engine has individual coil packs for each cylinder, and no distributor as such.
What appear to be "high tension" leads running to the plugs are in fact multi-wire ('low-tension') harnesses that include a power and ground wire, and a trigger wire from the computer that tells the respective coil pack when to fire its plug.
Image result for Ferrari 360 engine coil packs
FERRARI-360-3-6-99-05-GENUINE-BOSCH-IGNITION-COIL-COIL-PACK-NEW-0221504015
Thanks Bill, that makes more sense! However, where do all the leads go? I guess to they go to the Computer, I'll have to find out where that is...
... However, where do all the leads go? I guess to they go to the Computer, I'll have to find out where that is...
This diagram shows the main wiring harnesses in the 360. The computers are indicated by the red dots.
The sub-harnesses that run to the coil-packs are shown in gray, running as stubs out of the main engine harness. Kinda hard to see, but there.
(It's easier to make this out if you save the image to your hard drive and magnify it).
Ferrari 360 ECU Reset
Thank you very much! Where do you get all your info from?
  • 2 weeks later...
These would be out of scale size, as there are only three small wires, with some small split loom to protect them from the heat.
