I'd think it would be pretty straightforward. Make a flat plate to replace the timing cover. Make the toothed drive pulleys / sprockets out of flat styrene too, or maybe use a watch gear for the large upper one. Don't worry about the teeth on the sprockets / pulleys, as they're so small as to be too small to notice in 1/25 scale. Use a strip of tape for the belt. Then you'll have to get a water pump that will straddle the whole assembly.
Basically, just make what you see.
Image result for jesel belt drive      Image result for jesel belt drive  Image result for jesel belt drive
Joshua... Take a look at Dave's thread here. He has a jesel belt drive. you will have to go thru the pages because I don't remember exactly which they are on but you can see it in various pictures
Edited by Mooneyzs
