Just in case one of you guys will not use them, I will need parts D25 and D59, these are the support bar and the mirror that goes inside the front windshied. Any help with this will be appreciated.
Thank you!
Simón
Edited by simonr
Mike: Thanks a lot anyway for your try. I hope someone comes up with something, because, I sent my question also to Fujimi.com.nz with no seccses. Maybe someone here can tell me where I can address my request.
Simón
Lo Siento. Yo No Tengo.
I do have a 356B 1600S Roadster, which appears to not have those partos........
EDIT: I stand Corrected; here they are.
It would be great, if you can, please. Yes, most of these 356 kits(like with the 911's) share thier trees with some light variations. I support what you said, because, in my kit's there is a part that looks like the one I need and obviouslly is intended for a different variation of a 356. If you can post the picture I will appreciate it a lot. Thanks, Mike!
Simón P. Rivera Torres
Mr. Simon,
I think that the parts I have are what you need. both of those part #'s from my kit correspond to what you said you are looking for. If you wish, I could take a pic of them so you can verify. I'm pretty sure the same "D" tree is shared between the 356A & the 356B kits.
Yes, these are the parts. From what I seeing in the Fujimi bax picture, the rear mirror in the one you have, hangs from the front windshield frame. In the one I have the bar(part D 25) cross the windshield frame, as you can see in the box art included here. Just make sure you will not use the parts.
Thanks again!
Edited by simonr
[Mike, I already sent you a PM with my info.
Thanks again
Simón
quote name='Mr. Mike' date='Feb 18 2009, 01:59 PM' post='157531']
Simon, this car's windshield A-pillars were badly damaged (befor i got it - looked as if someone crushed the box in). my plan was to make a racer out of it w/ a cut-down window anyway. PM me your particulars, & i'll see what I can do to get this these to you.
