My drill is losing its grip, really, for any bit smaller than a #77. This tool is almost 30 years old now and i figure it may be time for a new one.
Thanks,
joe.
general makes a 4 part pin vice set.....will work from #80 to #1
You could swap out the collet to your old faithfull.......
Edited by MikeMc
I just use my Excel knife handle for mine.Mine is split clear across to form an x on the end of the ball when i tighten it. It clamps like the pin vise but tighter in the middle. Haven't used a pin vise for my smaller bits in years.
thanks for the suggestions. I have tried the masking tape thing with mixed results. I have an excel knife but cannot recall now if it is split in an "X" I think only a " l ".
Randy,
I really know what you mean about the wear and tear on the hands. That bit works down to #80?????
joe.
Joe, mine does, but to make sure ask the seller before you buy. If you do a Google search, Dr. Micro Tools has them on their website also, and theirs specifies down to #80. I got mine because I detail HO scale diesel locomotives, and drilling hundreds of holes for hand grabs and lift rings with a pin vise takes days.
Edited by Randytheroadrunner
If your wanting a good pin vise get a X-acto.
I tried all the brands a this one performed the best and will hold a #80 very tight.
Hope this helps you.
This is what I use also. I leave the plastic cap on the unused side and it turns perfectly for me. I also have a battery operated drill by X-acto. I have had, and been using this one since 1975. Runs on 2 c-cell batteries.
