Won this kit in a raffle, am thinking about a two wheel conversion. Do any of you have a suggestion on a way to do this? Thanks for any and all suggestions.
There are a few options, the best fitting one being the one-year-only '78 C10 by MPC. The Revell 64-65 C10 kits would also work, but you would need to swap out the trailing arm rear suspension with leaves. The later MPC/AMT C10 kits would be incorrect as they are torsion bar suspension.
The Revell '64/65 Chevy truck would be the easiest and most accurate currently available chassis. It would need shortened, or the suspension adapted to the Blazer kit frame. The coil suspension would be correct for a 2wd Blazer.
Side not, for anyone doing a '69 conversion, the '69 Blazer was only offered as a 4x4, no 2wd option.
