eddie Posted April 14, 2008 Posted April 14, 2008 I just bought the Revell Enzo Ferrari kit. I was doing a mock up on the bench and noticed that the bottom panel and body are pretty warped. so bad that the rear hood doesnt sit right. the bottom panel and body dont really match up too well. cant return it...is there a way to fix the warped pieces? any suggestions would be appreciated.
CAL Posted April 14, 2008 Posted April 14, 2008 I just bought the Revell Enzo Ferrari kit. I was doing a mock up on the bench and noticed that the bottom panel and body are pretty warped. so bad that the rear hood doesnt sit right. the bottom panel and body dont really match up too well. cant return it...is there a way to fix the warped pieces? any suggestions would be appreciated. depends on how warped. Hot water and trying to bend them back into place works to a degree.
Fuel Coupe Posted April 14, 2008 Posted April 14, 2008 I just bought the Revell Enzo Ferrari kit. I was doing a mock up on the bench and noticed that the bottom panel and body are pretty warped. so bad that the rear hood doesnt sit right. the bottom panel and body dont really match up too well. cant return it...is there a way to fix the warped pieces? any suggestions would be appreciated. Boil some water dip the offending part in said hot water. square up offending part by twisting just past where its straight and run under cold tap water. that should get you back in shape. repeat if necessary...
eddie Posted April 15, 2008 Author Posted April 15, 2008 Boil some water dip the offending part in said hot water. square up offending part by twisting just past where its straight and run under cold tap water. that should get you back in shape. repeat if necessary... thanks...worked like a charm...priming the pieces already...cant wait to get this one done.
