Ninth Step: Use the AXCTO Knife; mix the glue with the Putty. Let it dry for thirty minutes.
Tenth Step: Place the Brass Rod into the hole you drilled on the model car and cut to the desired length for the Antenna.
Eleventh Step: Paint the Antenna
Twelfth Step: Glue the Antenna onto the model.
So, there you have it. A simple way to create a Radio Antenna for your model kit. An added item to give the model that extra realistic look. Hope this helps you on your next modeling project. :D
Happy Modeling :D
Felix
Edited by TheCat
Nice tutorial Felix, but wouldn't it have been easier to follow the steps if they was all place into one thread instead of 3? :)
yup, I tried to do it on one thread, but there was too many images and the system did not allow me to save it as one. Maybe I'm doing something wrong.
Edited by TheCat
Nice Tutorial.
You could have posted all 3 installments as 3 separate posts in the same thread to overcome the photo limit.
Nice Tutorial.
That's what I always do. Just do like I do and add the part (continue from part#) so people would know where the newer part picks up from in the tutorial.
