guys I have a nice detailed 1:25th kit of a 67 camaro from revell but its the ss big block kit,   im looking to build a STOCK 6 cylinder engine car with stock flat hood and hubcap rims  where would I find these parts????
There are a few kits that have the Chevrolet 6 Cylinder. The first kit that I thought of is the AMT '60 Chevrolet pick-up from Round 2. The problem is it represents the predecessor to the 230 or 250 cu in 6 cylinder used in the Camaro. I think with a little work and a different Valve Cover and upper hose mount and Air Cleaner it could be used and the other differences from the 235 cu in found in the truck kit. Chevrolet started offering a little more advanced 6 cylinder engine around '63 with the introduction of a 194 and 230 cu in engines. Starting in '66 they changed to the 250 cu in displacement on the 6 cylinder. I can't think of any kits with the true 250 cu in engine in your '67 Camaro build, but again I think you could git close enough with the truck kit or check any of the casters on the forum to see what they have to offer.
The AMT '67 and '68 Z/28 kits have the hood you want, but it might require some tweaking or modification to fit your Revell body. Your kit has the desirable "stinger" hood; perhaps someone here would like to swap hoods with you.
Perhaps if you post this in (or ask an Admin to move it to) the "Where Can I Get" forum...
Edited by BigTallDad
