I was hoping someone here has used this paint on a model. If so...did you clear coat it?
I used it years ago and cleared it with Dupli Color Acrylic Lacquer, but it wrinkled up on me...yea I know it's because of the enamel vs. lacquer.....but back then I didn't.
Now I want to know if there is a clear that I can put over it without ruining it.
TIA :)
I have used them all. the only one I stay away from is the satin blk or blk primer. they seem like they never dry. the only top coat I use is Urethain. Never tried it with anything else. But Urethain I the only stuff that can go over anything, unless you go enamel over lacquer.
hmm , never tried Urethane before. I don't use those soft paints either, I agree with you. I wonder if some Krylon clear I have would work on it? I am not looking to go to any great lengths here, I just might clear the paint and polish it out a little. The paint it'self "etched" on me so I am wanting to smooth it out a bit. I can polish the paint....but I don't want to rub through.
Dupli-color does make a can of Engine Enamel Clear that goes with the engine enamel colors.
I have used it and found that it gives a nice gloss, but definitely needs polishing due to orange peel, but that could also be my spray technique.
First, I wouldn't recommend an enamel based clear, as it will yellow over time. I've become a believer in Future acrylic floor finish....that stuff rocks! Any acrylic clear should be ok.
Automotive urethane IS the best to use, but #1, its pricey, and #2, use a respirator.
Edited by roadhawg
  Tom Kren said:
I have tried it too works great but not the clear but i dont use clear anyways!
you don't use clear on anything? you rattle can or air brush?
  Tom Kren said:
RIGHT OUT OF THE CAN AND JUST USE RUBBING COMPOUND.
you are good Tom! I would rub through the paint, I have to use clear to protect myself haha!
