Kelly Posted Monday at 11:56 PM Author Posted Monday at 11:56 PM 2 hours ago, johnyrotten said: Don't necessarily toss the pen just yet. If it's an alcohol based chrome, I've unscrewed them and used the ink with a brush, and airbrushed the ink. The pens do have a tendency to stop working or leak. Thanks but I already threw in out I am going to buy another one and try it on something else later I liked the finish it left 1
Kelly Posted yesterday at 12:08 AM Author Posted yesterday at 12:08 AM 21 minutes ago, mcs1056 said: If this isn't solved, and you want to keep the good chrome on the bumper, perhaps one of these will work... 1. A fiberglass abrasive pen. 3 ea. for $7 today on Amazon. Search "Fiberglass Scratch Brush Pen." 2. Abrasive sanding sticks. These are heavy grit. $9.99 today on Amazon. Search "Leriton 60 pcs Sanding Sticks Double End." 3. A fairly fine paint brush. Hold the bumper so the "well" you're trying to strip is level. Brush on some paint stripper. Wash and repeat with whatever you'd use to strip the chrome. 4. A disposable micro-applicator. Same process as (3), above, but much smaller. $11.99 on Amazon. Search "400 Regular Micro Applicators - Disposable Dental Brushes." 5. A stick. I cut a piece of a fingernail sanding stick and glued it to a stirring stick. The one pictured is bigger than you'd need, but you can make custom. I see no need to chuck that bumper. I hope this, or any of the great ideas presented so far, gets you through this. Thank You I like #5 I am going to use the idea on a build coming up soon to do the same type of painting or a wash on a rear bumper panel You’re idea might easy for me to do. Thanks Kelly
StevenGuthmiller Posted 23 hours ago Posted 23 hours ago 1 hour ago, Kelly said: Thanks but I already threw in out I am going to buy another one and try it on something else later I liked the finish it left If you’re steady enough to use a pen, you’re certainly steady enough to master foil, which is going to give you a much better and undoubtedly more durable finish than a pen ever will. There’s a reason why the pros use foil. Steve 1
Kelly Posted 23 hours ago Author Posted 23 hours ago 21 minutes ago, StevenGuthmiller said: If you’re steady enough to use a pen, you’re certainly steady enough to master foil, which is going to give you a much better and undoubtedly more durable finish than a pen ever will. There’s a reason why the pros use foil. Steve I agree with you wholeheartedly I did get some bmf and I am going to use it on the window trim My hands are steady sometimes! I have watched a few videos of the pros using foil and I feel confident I can do it Thanks so much for your input, appreciate it. Kelly
Bills72sj Posted 19 hours ago Posted 19 hours ago While you have had a couple of mishaps, do not let it discourage you. It has happened to ALL of us at one point or another. I am glad you have the willingness to learn. Because this is the best place to get an education in modeling. After awhile you will be doing much more "trial" and way less "error". 1
Beans Posted 11 hours ago Posted 11 hours ago I have had chrome pens do that to me several times before I finally gave up on them. Currently I am trying to master the foil. I seem to have the hardest time getting it to stick. I also use the pen to glob a bunch out and brush it on sometimes. The moral of the story...keep at it. Every model gets a little better but mishaps will happen...just keep swimming. OH and if you do use the easy off to strip paint don't leave the model in it too long. I left one overnight once and the next morning had a gooey plastic blob where the body used to be.
Kelly Posted 6 hours ago Author Posted 6 hours ago 12 hours ago, Bills72sj said: While you have had a couple of mishaps, do not let it discourage you. It has happened to ALL of us at one point or another. I am glad you have the willingness to learn. Because this is the best place to get an education in modeling. After awhile you will be doing much more "trial" and way less "error". Thanks With the response I have received here I am definitely getting the education I need Everyone has been so helpful
Kelly Posted 6 hours ago Author Posted 6 hours ago 5 hours ago, Beans said: I have had chrome pens do that to me several times before I finally gave up on them. Currently I am trying to master the foil. I seem to have the hardest time getting it to stick. I also use the pen to glob a bunch out and brush it on sometimes. The moral of the story...keep at it. Every model gets a little better but mishaps will happen...just keep swimming. OH and if you do use the easy off to strip paint don't leave the model in it too long. I left one overnight once and the next morning had a gooey plastic blob where the body used to be. Thank you Foil is on the table I am going to try it when I get back to the build 1
