jjsipes Posted June 29, 2017 Posted June 29, 2017 I have seen black engine blocks and blue engine blocks. Does anyone know for sure what color the engine blocks were?
CometMan Posted June 29, 2017 Posted June 29, 2017 That would depend on which engine you are going for, and when, Jason. If you are building an 8 cyl., an occasional black one did get produced, but the vast majority of them were Ford Medium Blue. If you are building a 6 cyl., the ones built before 6-1-65 were Red-Orange, the ones built after that were Medium Blue. Either way, the Medium Blue is what everyone thinks of when they think of Ford engines from that era. Hope this helps.
Force Posted June 29, 2017 Posted June 29, 2017 (edited) I'm not 100% sure but I think Mercury followed the Ford model line engine colors in the 60's, in that case the engine should be black with different colored valve covers and air cleaners depending on engine version from 1959 up to at least midyear 1965...and blue from midyear 1965 or 1966 to 1968, from 1969 to 1974 the engines were lighter blue than the 66-68. Edited June 29, 2017 by Force
my66s55 Posted June 29, 2017 Posted June 29, 2017 I'm not 100% sure but I think Mercury followed the Ford model line engine colors in the 60's, in that case the engine should be black with different colored valve covers and air cleaners depending on engine version from 1959 up to at least midyear 1965...and blue from midyear 1965 or 1966 to 1968, from 1969 to 1974 the engines blue than the 66-68.This answer is totally correct. The 65 full size Mercury engine was black with orange valve covers and air cleaner. I ran into this situation when I was building my full size 66 Mercury S55 convertible. The 66 brochure showed the 65 engine. Wrong colors for 66.
Jon Haigwood Posted June 29, 2017 Posted June 29, 2017 Not sure if the Mercs were the same.YEARENGINEBLOCK AND CYLINDER HEADSAIR CLEANERVALVE COVERS1959223BlackRedRed1959292BlackRedRed1959332BlackGreenGreen1959352BlackBlue* Blue1960223BlackRedRed1960292BlackRedRed1960352BlackBlueBlue1960352HP BlackGold open-elementGold1961223BlackRedRed1961292BlackRedRed1961352BlackBlueBlue1961390BlackSilverSilver1961390 HPBlackGoldGold1961390 HP-6VBlackOval aluminumGold1962223BlackRedRed1962292BlackRedRed1962352BlackBlueBlue1962390BlackSilverSilver1962406-4VBlackGold open-elementGold1962406-6VBlackOval aluminumGold1963223BlackRedRed1963289BlackWhiteWhite1963352BlackBlueBlue1963390BlackGoldGold1963406-4VBlackGold open-elementGold1963406-6VBlackOval aluminumGold1963427-4VBlackChrome open-elementChrome "baldies"1963427-8VBlackOval aluminumChrome "baldies"1964223BlackRedRed1964289BlackRedRed1964352BlackBlueBlue1964390BlackGoldGold1964427-4VBlackChrome open-elementChrome "baldies"1964427-8VBlackOval aluminumChrome "baldies"1965240BlackRedRed1965289BlackWhiteWhite1965352BlackGoldGold1965390BlackGoldGold1965427-8VBlackOval aluminumChrome "pentroof"1965427 SOHC-4VBlackChrome open-elementCast aluminum1965427 SOHC-8VBlackOval aluminumCast aluminum1966240Blue**BlueBlue1966289BlueBlueBlue1966352BlueBlueBlue1966390BlueBlueBlue1966427-4VBlueChrome open-elementChrome "pentroof"1966427-8VBlueOval aluminumChrome "pentroof"1966427 SOHC-4VBlueChrome open-elementCast aluminum1966427 SOHC-8VBlueOval aluminumCast aluminum1966428BlueBlueBlue1967240BlueBlueBlue "PBF"***1967289BlueBlueBlue "PBF"1967390BlueBlueBlue "PBF"1967427-4VBlueBlueTall Chrome "PBF"1967427-8VBlueBlueTall Chrome "PBF"1967427 SOHC-4VBlueChrome open-elementCast aluminum1967427 SOHC-8VBlueOval aluminumCast aluminum1967428BlueBlueBlue "PBF"1968240BlueBlueBlue "PBF"1968302BlueBlueBlue "PBF"1968390BlueBlueBlue "PBF"1968427BlueBlue w/chrome lid TallChrome "PBF"1968428BlueBlueBlue "PBF"1969240Blue****BlueBlue "PBF"1969302BlueBlueBlue "PBF"1969351BlueBlueBlue "PBF"1969390BlueBlueBlue "PBF"1969429BlueBlueBlue "PBF"1970250BlueBlueBlue "PBF"1970302BlueBlueBlue "PBF"1970351BlueBlueBlue "PBF"1970390BlueBlueBlue "PBF"1970429BlueBlueBlue "PBF"1971302BlueBlueBlue "PBF"1971351BlueBlueBlue "PBF"1971390BlueBlueBlue "PBF"1971400BlueBlueBlue "PBF"1971429BlueBlueBlue "PBF"* The blue used on these engines is very similar to the lighter blue used on the late-'60s Ford engines. ** The blue used on 1966-1968 Ford engines is a darker blue than used on earlier Ford 352 valve covers. The correct color is TRW #630224 or Eastwood's "dark Ford blue."***"PBF" indicates "Power by Ford"**** 1969-1974 Ford engines were a lighter blue than 1966-1968. The color is similar to the early 352 valve covers.
Force Posted June 30, 2017 Posted June 30, 2017 This answer is totally correct. The 65 full size Mercury engine was black with orange valve covers and air cleaner. I ran into this situation when I was building my full size 66 Mercury S55 convertible. The 66 brochure showed the 65 engine. Wrong colors for 66. I have seen pre 66 Mercury's with black engines and gold or chrome valve covers and air cleaners, that's why I assumed they followed the Ford line.I haven't found any list of engine colors for Mercury's other than the flatheads.
dodgefever Posted June 30, 2017 Posted June 30, 2017 The standard Mercury 289 was black with yellow valve covers and air cleaner. The Cyclone engine was black with silver valve covers and air cleaner, or black with chrome for the HiPo engine.
