BMF - My brain has a larger appetite then my physical skills but I tried my best.  Gold plated fire wall detail with BMF that will be mostly hidden by the motor. Complex surfaces and small space to work with.
  • Like 2
MM, looks perfectly good to me. Worst thing about BMF is getting the tiny wrinkles in it. I do not see any in your work. That engine looks amazing. Can't wait to see some color on it.
  • Thanks 1
Dual Fuel tanks sprayed gloss black and fused into chassis. Misted Tamiya primer onto the two main body parts and began to close the hole / gap made visible between the wide fender flairs and main body with puddy. I will work on removing mold seams lightly as I’ve done the medicore hood pins / latches and try to avoid any fine scratch left.
Edited by Technics
Fantastic looking 3D-printed engine here - I have the Fujimi Enthusiast series stratos with full engine detail, but this one is much more crisp and delicate: the carburettors, the spark plugs!!!
@1959scudetto Thank you. Yes I have a unbuilt fujimi kit as well. I think this kit is more accurate on the exterior but lacks the motor. A 1:12 doyusha kit awaits for a future build one day, that thing is a monster!
  • Thanks 1
I went onto drilling 1.8mm wide holes for the strong but tiny 2x1mm N52 gaming magnets I decided I want to have holding the rear clamshell together. I placed them into the recently filled gaps that were created from the large rear fenders which I filled.
It all worked out fine, I will need some help closing the gap along the roofline. It might get solved when I mount the hinge wire and permanently fix the clamshell hinges which will limit the movement.
I never done any of these processes as removing bonnet pins, separating body panels, using magnets ( in this scale ) but always admired those that could / willed to. It is very exciting to do, 20 years later!
  • Like 5
  • 3 weeks later...
at the last GSL - one [of several] features that separated Scale Master's and Randy Derr's 12th scale builds fr the hundreds of other entries were their effective use of magnets to fix moving and removable parts of the body shell ...   ...   ...
I have never heard of gaming magnets. Can someone post a close-up view of them and what is the original reason for their existence. I've had some hoods in the past that this might have been a fix for.
Most components are now fused onto the motor and it has been primed in Tamiya light grey. The motor needs to be final mounted into the frame to have more details and auxiliary items attached. I will begin painting on layers and doing details I can manage using some of the bottom photos as inspiration.
  • Like 3
I decided I wanted the original box art livery. Maybe its too obvious but I went with the final gut feeling.
Some alignment issues which I will sort. Tricky but rewarding decal process on its way.
  • Like 3
Looking good MM. I hope you're not going to try dealing with those vents in the hood. That would take a steady hand and no room for error. Might not be possible to deal with.
  • Thanks 1
If you're going to slice up the hood vent decal, use a new blade!  Will still need some green touch up paint after the knife work.
Good luck with it!
  • Thanks 1
  • 4 weeks later...
Majority of decals on. Some brutal that put up a fight. Micro Sol, Set, and Tamiya decal glue make it possible though. Definitely a challenge I never knew I’d be able to tackle. I mixed up some touch up paint in green as it will be needed in areas. I later realised the kit refers to the exact green by Mr.Color so I picked some up.
I would be happy to have the exterior sealed in matt clear this year. I will aim for that!
  • Like 4
Fantastic conversion on this & a beautiful build.  I've always loved the Lancia Stratos, such a classic sports car, especially the Alitalia sponsored race versions.  Great job.  I will certainly follow this one to the end.
  • Thanks 1
