sharkyrkk Posted October 30, 2014 Posted October 30, 2014 Hey Guys, I have a How-To for the experts. I bought a '70s Pantera that came without a drive train. I want to build a 427 Ford and trans axle. Has anyone ever done this? It will not be easy, but will make a cool build. Thanks for any help. Ray
64SS350 Posted October 31, 2014 Posted October 31, 2014 Google it and you can get some great pics to start from
Ace-Garageguy Posted October 31, 2014 Posted October 31, 2014 (edited) I've restored several real Panteras and heavily modified others, so maybe I can help some. As you probably know, the cars came stock in the '70s with the Ford 351 Cleveland engine, and a ZF gearbox. A 427 will be a little tight in the engine bay, but it will fit. I've seen real ones with big-block Chevy engines as well. An excellent engine source for the 427 is the old Revell Parts Pack version...cheap and readily available. I don't recall a source for a correct ZF transaxle right off hand, but a Porsche 911 gearbox mounted backwards can supply a looks-good-at-first-glance alternative if you're not too concerned with accuracy. The old AMT Hardcastle & McCormick Coyote could supply a decent starting point for front and rear suspension, though the gearbox in the kit looks nothing like the correct ZF. This is a ZF...doesn't look much like any of the available kit-sourced mid-engine transaxles. This Porsche gearbox is a fair approximation... If you're building close to stock, the headers are pretty mundane, like these, and tuck close to the sides of the block. Most of the images of "Pantera headers" on Google are wildly modified cars. Edited October 31, 2014 by Ace-Garageguy
Crazy Ed Posted October 31, 2014 Posted October 31, 2014 The Hewland Transaxle from one of the AM McLaren M8B's removed fron the Chevy and mounted upside down will result in a simular looking Transaxle and if you really want to go into detail the rear plate will need some work. Another nice transaxle is in the Fujimi Porsche 917k.
Ace-Garageguy Posted October 31, 2014 Posted October 31, 2014 (edited) The Hewland Transaxle from one of the AM McLaren M8B's removed fron the Chevy and mounted upside down will result in a simular looking Transaxle and if you really want to go into detail the rear plate will need some work. Another nice transaxle is in the Fujimi Porsche 917k. I started to recommend the AM Hewland, as I've seen 1:1 Panteras with that gearbox. I looked in an AM McLaren kit however, and the 1/24 Hewland LG 600 looks to be pretty huge compared to what a scale-correct ZF would be. Besides turning it over, you'd also have to add an engine mounting flange and remove the control-arm mounts from the side covers. If your Pantera kit is 1/24, you'd probably be better off installing the Hewland right-side up, and letting it just be a Hewland rather than trying to hack it into a ZF. With the 427 you want to use, the big Hewland would be just right (too much is always good). Hewland LG 600 Now that I'm really thinking about it, I'm pretty sure I've seen a gearbox in some obscure kit that would make a quite-believable stand-in for the ZF. If I figure it out, I'll put up a photo. Edited October 31, 2014 by Ace-Garageguy
LDO Posted October 31, 2014 Posted October 31, 2014 I have one of those McLarens. It was on sale. I got it just for the engine and its awesome induction system. (I think those intake trumpets would look awesome poking through the hood of a AMT's Baldwin-Motion '70 Camaro). If the OP wants to talk trades, I'm looking for a resin '27 T roadster body.
sharkyrkk Posted November 1, 2014 Author Posted November 1, 2014 Thanks for all the suggestions. I need to digest and then sort. I am also going to sift thru all the resin parts floating around. Thanks again.
vamach1 Posted November 20, 2014 Posted November 20, 2014 I would think the MPC MKIV GT40 engine/trans would be a natural fit.
Ace-Garageguy Posted November 20, 2014 Posted November 20, 2014 I would think the MPC MKIV GT40 engine/trans would be a natural fit. They fit well enought, but look nothing like the 351C engine and ZF gearbox in a production Pantera. While the big-block Ford engine from the Mk4 kit looks 427-ish (as the OP wanted) the gearbox is entirely different.
Jeremy Jon Posted January 4, 2015 Posted January 4, 2015 (edited) Hey Ray & Bill, send me a message, I developed a ZF tranaxle proper for my Cizeta V16T build (below is 3 separate pieces, engine, bellhousing, transaxle) which should be correct for you, just adapt bellhousing from donor engine used Edited January 4, 2015 by Jeremy Jon
