Man, you do nice work! This is some of the finest scratchbuilding I've seen in smaller scales. Outstanding, and a real inspiration to watch your progress.
Thanks Bill - I'm glad to do so, as you can tell, I really enjoy the construction of these models from scratch, even over painting & detailing a build version!
Thanks Kerry & Michael!!
I decided to to build an AMC engine from scratch, started with a generic V8 block & heads, which have no detailing what-so-ever, and will highly modify
10168021_615445428549170_793473694444694
Adding detailing of the OEM castings, and scratch building other components, like oil pan
1972422_615445951882451_6220900259737587
Unique bellhousing, with ribbing, constructed, starter attached, and primer coated
10171176_615446255215754_244398067169302
AMC specific intake (dual plane) manifold being constructed, to properly replicate production part, including noticable offset between cylinder banks
10155319_615446541882392_275076971555400
Intake manifold complete, and cylinder head casting details added, including indents for spark plug wires to attach, and bolt head detail
10253926_615447281882318_699176501876112
Edited by Jeremy Jon
Major engine components completed; block, intake manifold, cylinder head, oil pan, each in primer coat
10247199_615939391833107_492110661693457
Stationary fitment of parts together, next is front accessories construction & cast second cylinder head + carburator
10292288_615939851833061_350256585615072
Started fabrication of the bespoke transaxle, test fitment to bellhousing, using a donor & highly modified transaxle 10299952_615940508499662_217748765299712
Near completion of transaxle, including rear case cover and bolt head detail
10153976_615943175166062_791652160294788
A couple-three pics before the weekend! :)
All major drive train components completed, test fitted and hard primer coated, ready for casting!
10153829_616943025066077_770070330876937
Construction of ancillary components, timing cover, water pump housing & pulley, crank pulley & damper, and distributor with vacuum advance housing
10290613_616943168399396_705971813674884
Test fitment of ancillary components together, as they will look on assembled engine ...a few small details, like bolt heads & oil filter extension, and these will be complete!
10153970_616943918399321_459020779392776
Simply Amazing!
I am in awe of your plastic skills here!
WOW!
This is "thee" embodiment of research and "fun!"
You have combined both worlds of plastic modeling
Researching a finely detailed scale model "AND" just plain having fun and enjoying it!
Thank You so very much for sharing with Us
Looking forward to seeing more
Later
Russ
Awesome demonstration of expert scratchbuilding. I'm thoroughly enjoying watching this come together. Keep 'em coming!
OEM log style manifolds constructed, for right & left side
1538777_619424971484549_9031544918247860
More construction of front accessory components, adding alternator & bracket (integral) and fuel pump, with key-way notches added to block for alignment during assembly
10310634_619425308151182_258055291933851
Entire front accessory component assembly(s) completed
10273417_619425974817782_733652332245694
Mock up of entire front accessory component assembly(s) completed
10174918_619426081484438_273458034113728
Man, oh Man, oh Man . . . . .
I am just totally flabbergasted by Your scratch building on this!
Whoa! This is making my eyes bulge Man!
Your abilities really shine with build!
I m going to look up some of Your other work here if i can find it!
WOW!
I really do Thank You for sharing with Us here too!
I am really learning a lot with this!
Thank You again, cannot wait to see more of Your work!
Later
Russ
Thanks Russ, my pleasure!
I have a few projects on the go, I don't necessarily post them each here, but are on my FB page if you're interested
10169346_619433524817027_135678113733124
  • 1 month later...
