Clear parts adhesion question
i use modpodge for clear parts and it works great. one thing to note, if the piece is ill fitting, it wont work.
the modpodge dries very clear and if you mess up you can wipe it with water and start again. it says it takes 24 hours to fully cure, but honestly, 1 hour is enough for me.
for tough fitting pieces, where something is warped or just very ill fitting, i use gorilla clear. it holds much better, but there is less room for error with that.
Testors makes a clear parts glue, comes in a black plastic bottle like their regular cement does ( not the orange tube stuff). That's what I use. It can be real stringy and messy if you put on too much, just a heads up.
Edited by Dave G.
 Share
