matthijsgrit Posted 12 hours ago Posted 12 hours ago Question is this: I wanna make a car with a partly white interior. The parts are black though. What's a good way (use of primer etc) to get the whitest result? Any help will be greatly appreciated.
bobss396 Posted 11 hours ago Posted 11 hours ago Good question. Whatever you do, it will take more than one coat. Maybe start with a light gray like Tamiya has and then their white over that. 3
Beans Posted 10 hours ago Posted 10 hours ago I would start with a white primer. I haven't ever tried this but that is where I would start. Probably duplicolor white primer. That seems to cover well for me. (depending on what paint you are using over it of course)
stitchdup Posted 9 hours ago Posted 9 hours ago i'd use grey primer and treat the white primer as the top coat. if you start with white you'll end up with very thick paint 6
peteski Posted 9 hours ago Posted 9 hours ago Why? Is the gray primer more opaque than white primer? Wouldn't 2 coats of white primer have same thickness as a coat of gray and a coat of white?
Zoom Zoom Posted 8 hours ago Posted 8 hours ago Tamiya TS-101 Base White. By far the best white primer I've ever used. Very pigment dense, covers quickly, dries to a slight semigloss sheen. It's worth seeking out. Their regular white primer is quite good, but nobody's white primers I've tried even comes close to this stuff. Black plastic? No problem. Worth the $$, it saves you in the long run by conserving the paints applied over it. 3
stitchdup Posted 8 hours ago Posted 8 hours ago i find the white takes more coats to cover. a single coat of grey will cover black but it can take 2 or 3 with white to get the same coverage. a single coat of the white will cover the grey, plus using grey first shows up any parts needing a bit more work better than white would. i should point out i use automotive primers 1
matthijsgrit Posted 7 hours ago Author Posted 7 hours ago Thanks people! I use Tamiya TS paints and have some nice ideas to try now. 1
bobss396 Posted 7 hours ago Posted 7 hours ago Got it... how about Zinsser stain block primer? I've used it on water stained dry wall. Or silver paint? Practice on some scrap first.
jaymcminn Posted 5 hours ago Posted 5 hours ago 2 hours ago, Zoom Zoom said: Tamiya TS-101 Base White. By far the best white primer I've ever used. Very pigment dense, covers quickly, dries to a slight semigloss sheen. It's worth seeking out. Their regular white primer is quite good, but nobody's white primers I've tried even comes close to this stuff. Black plastic? No problem. Worth the $$, it saves you in the long run by conserving the paints applied over it. This is the correct answer. Unbelievable how well this stuff covers. 1
Bainford Posted 5 hours ago Posted 5 hours ago I wish the Tamiya primers would return to Canada. I've been intrigued by TS-101 Base White since I first heard of it a few years ago. When the Tamiya primers disappeared from the shelves, I stocked up so I'm good for a few years, but could never find the Base White.
matthijsgrit Posted 2 hours ago Author Posted 2 hours ago I think I'll visit a hobby shop tomorrow and look for some Tamiya TS-101. i'm from Holland, we still have the Tamiya paints. This one, I never looked for it so fingers crossed. I trully appreciate y'all's input !! Thanks!!
