Yeah, it really stinks, b/c I had really been planning to go 'til I realize this conflict had come up...
We'll be thinking of ya!!!!!! Like I say, there's always next time. We ain't going anywhere!!!!! LOL
Thanks for the thoughts, Kerry. I also sing in a men's barbershop chorus and our annual show is that same day/night (two performance) that we've been practicing for, for the past several months...
Thanks Dave! More to come.
Thank you, so much, Leonard. It's great hearing from you. I'm glad to see you're back on your SS Camaro build.
To continue progress on my wheelie bars, I need to check fit under the car. To do that, I had to reattach the chassis-side 4-link brackets, which I prematurely installed quite some time back, only to discover that they really needed more gluing surface than what the cast-in-place guides offered.
Last night added some thinned-down .040"x.040" strip to provide more surface and strength. Sorry the pic isn't a little more in focus but I think you get the idea.
With the brackets installed.
As I said earlier, there's no room at the inn under here. The tire/wheel assemblies are just floating on the rear end so there's actually a bit of latitude in spacing everything, but not much...
While it's not bad, I'm not 100% happy with where the ride height is at at the present time. I am thinking about building another set of shocks with shorter springs, then space the mounting as necessary to get me where I want it to be.
Wall to wall tire...
Thoughts/comments welcome. Later!
Oh my!!! This is looking great. I love seeing the rear end in. That is some mighty fine work brother. Glad to see more progress on this. Can't wait to see what you show us next.
Scott, that just looks plain ol' flat out mean to the bone. I see how shortening the shock springs might help as long as the wheel wells cooperate. It looks like the top of the wheel center would be at the same level as the bottom of the fender too.
I look forward to the next installment.
I'm glad we see eye to eye, Kerry! :)
Thanks Brad. I'm glad to be back on it, too.
Hey Chris... Thanks brother. I'm pretty stoked about how it's shaping up.
I totally understand what you're saying Joe. There's a fine line between settling the body down over the tires a bit more without contacting the inside of the quarters, while still maintaining at least a smidge of separation between sidewalls and the frame/suspension. I've probably got a max of about .080" to work with before the tires are touching the tubs. IF I can get it down .060" I'd be very happy. Don't know if it'll happen or not.
Haven't had much time to work on it the last couple nights but did succeed in finishing the ends of what would be the axles on a 1:1, so you can't see the aluminum tubing and raw end of the axle/hat assembly any more. Looks much better and will post a pic of that next time.
Edited by futurattraction
OMG.... what great job on that Fairmont. First I was surprised to even see a Futura, then as I look through the pages, I became painfully aware of just little I know about building model cars.
Thanks for sharing this build, I am truly in awe! Can't wait to see it finished.
  • 1 month later...
I’ve made a bit more progress since I last posted. I got “caps” added to the ends of the axles so the aluminum tubing of my axles will no longer be visible and represents a much more finished appearance. And this pic shows the wheel studs and nuts I've added. The wheels will unbolts from the axles - at least at this point.
fairmont%20and%20other%20006_zpshsbwxeza
As you may recall, I had worked on the upper tubing for the wheelie bars. As it turned out, I had to reduce the distance between the upper and lower tubes to create clearance between the underside of the trunk floor and the upper tubes. No wheelie bar tunnel, here... Thankfully, it wasn’t a major undertaking to remove the spanners between the two, thought I've now got some extra cleanup to do on the tubes. Interestingly, it wasn't until I looked at my pictures that I realized that I either hadn't glued the spanner to the upper tube or it was so lightly glued that it came loose, as seen here. I'm much happier with the ride height, as seen in this shot. These two shots also show a detail I added to the rear deck spoiler that I'm very happy with. I had some photo-etch brackets made that help support the underside of the spoiler.
fairmont%20and%20other%20016_zps67cesmlr
fairmont%20and%20other%20020_zps95wp4pph
This underside shot shows how closely things fit and also the coil-over shock spacers I used to establish the ride height.
fairmont%20and%20other%20022_zpsjla1kgc4
This is just kind of a cool angle. I have photo-etch spill plates that I will add when I'm much closer to being finished with the body.
fairmont%20and%20other%20017_zps21oox4kp
And another:
fairmont%20and%20other%20013_zpstiuvirey
I plan to fab some 1/16th aluminum tubing 4-link bars that will taper at the ends to replicate the weld-in threaded tubing adapters. Those, and getting repairs made to the front of the chassis so I can actually get this contraption to set on all fours are a couple of my upcoming projects.
Comments welcome!
