#1 model citizen Posted October 30, 2017 Posted October 30, 2017 (edited) Greg, Your list & others responses is very helpful. I will have to look at the link Snake put up as well.Although I am aware of the DeSoto engine in the '53 Ford PU kit, I didn't know about the Lincoln.I started model building around 1960 at age 8 & continued through high school then off & on until this last year when I've had more time to devote to the hobby. I have never been able to identify every engine by sight or all of the nuances of the some ones I am familiar with. It has always irked me when a kit did not identify what the custom or competition engine is.I do remember a time when the engine swap w/o modification was a selling point for AMT.As I recall these were relatively crude with a hole for the metal axle to pass through and the transmissions were all nearly identical in order to accommodate the swap. Edited October 30, 2017 by #1 model citizen
Ace-Garageguy Posted October 30, 2017 Posted October 30, 2017 Here are links to the relevant Lincoln engine threads on this forum.
#1 model citizen Posted October 30, 2017 Posted October 30, 2017 Here are links to the relevant Lincoln engine threads on this forum.Thanks, Bill!
Bucky Posted October 30, 2017 Posted October 30, 2017 The AMT '49 Mercury had a nice MOPAR 440 Cross Ram mill. I used it in an AMT issue of the Dodge Li'l Red Truck kit.
Can-Con Posted October 31, 2017 Posted October 31, 2017 The AMT '49 Mercury had a nice MOPAR 440 Cross Ram mill. I used it in an AMT issue of the Dodge Li'l Red Truck kit.Well, IIRC, that's actually a 426 wedge, Keith. Remember, that Mercury kit was first released years before the 440 was made. 1
Greg Myers Posted October 31, 2017 Author Posted October 31, 2017 However, just like so many different engines, they look the same on the outside only differences being the boar and stroke, i.e. CID. I thought it was a 413.
Mark Posted October 31, 2017 Posted October 31, 2017 The Mercury kit was first issued in '63...probably went into development in '62 so it would have been a 413. I'd like to see how long that adapted Ford/Merc transmission would hang in behind a 413... 1
Greg Myers Posted October 31, 2017 Author Posted October 31, 2017 Small block Chevies, 265 - 400 Pontiac 326- 454 Small block MOPAR 273 - 360 Big block Mopar 413- 440 and many others, cubic inches varying and approximate.
Bucky Posted October 31, 2017 Posted October 31, 2017 You guys are probably correct. The kit I'm referring to was issued in 1991. Kit number 6815. It has a pic of the engine on the side panel, and calls it a 440. Also, the description on the other side panel about the kit calls it a 440.
junkyardjeff Posted November 8, 2017 Posted November 8, 2017 I put that 413 Chrysler motor from the Merc kit in a 51 Chevy I am building,I also picked up a few of the 390 motors from the 34 p/u kit to put in the 40 fords when I want a different motor and easy to install. I wish there would have been some Y blocks made that would go in without chopping the trans down to fit.
unclescott58 Posted November 8, 2017 Posted November 8, 2017 It sounds as if you may be a bit miffed that an old topic has been posted in a new thread, even though you were gracious enough to contribute your knowledge. I'm relatively new to this site too & I'm sure there are many topics that I would be interested in & questions I may have or will have that are already covered somewhere on this site, but with almost 18,000 topics just in this here "General" section alone and no index or other way to find the threads one would want, it is inevitable that new threads on the same topics will arise. I would have never found the earlier discussions on this topic but have found this one quite informative. If you would post links to the earlier threads that would be helpful too. I would like to thank you & all the other contributors to this thread and hope you all will forgive us newcomers and continue to share your knowledge and expertise. It is very much appreciated, I've been around a while now. And have seen this subject brought up before. But, going back and finding the older threads on certain subjects is not always easy. And as you noted, if didn't know it had been done, even tougher yet. I do not mind when things like this come up again. It maybe old news. But, it's still interesting old news. And sometimes it will bring a new twist on a subject. Or a new person may know something that others here did not. I hope we keep bring back old topics like this from time to time. I'm enjoying read this one.
Greg Myers Posted October 22, 2019 Author Posted October 22, 2019 Still thinking about the AMT engine options, I realized they also came with a stock option, imagine that. The point here though, is most having a flathead Ford V-8, none of the early kits had any speed equipment for the flatty.?
Richard Bartrop Posted October 22, 2019 Posted October 22, 2019 3 hours ago, Greg Myers said: The point here though, is most having a flathead Ford V-8, none of the early kits had any speed equipment for the flatty.? So true. I remember patiently gluing pieces of wire on the heads of a stock AMT '40 Ford V8 to try and make a set of finned heads. On the other hand, the '27 T came with a Frotenac head, and of course the first version of the '29 A roadster had some vintage speed parts, so it you wanted to hop up an ancient 4 banger, you were good. 1
espo Posted October 23, 2019 Posted October 23, 2019 9 hours ago, Greg Myers said: Still thinking about the AMT engine options, I realized they also came with a stock option, imagine that. The point here though, is most having a flathead Ford V-8, none of the early kits had any speed equipment for the flatty.? Try and find an AMT '49 Mercury kit or the '50 Ford Convertible/Hardtop kit. They both offered some pretty nice finned aluminum heads and two - twos. I think the Revell '37 Ford pickup and their early '40 Ford pickup had some heads and carb's also. The Revell '50 Ford F-1 pickup had the Arden heads and three - two's if that is of interest.
Ace-Garageguy Posted October 23, 2019 Posted October 23, 2019 10 hours ago, Greg Myers said: Still thinking about the AMT engine options, I realized they also came with a stock option, imagine that. The point here though, is most having a flathead Ford V-8, none of the early kits had any speed equipment for the flatty.? But remember...when the first-generation AMT kits were released, for the most part, flatheads were considered obsolete boat-anchor scrap metal. The junkyards were already full of cheap, stock, late-model OHV engines that easily made the power of a heavily modified flathead, with better reliability and less weight. Go-fast flatheads were kinda dying out. That first AMT '32 roadster came with an optional Chrysler Firepower hemi, and at about the same time, Hot Rod mag published an article about choosing junkyard engines based on performance potential vs. weight vs. cost. The numbers added up to the hemi being the most bang for the buck.
Richard Bartrop Posted October 23, 2019 Posted October 23, 2019 You did get some interest in the 4 cylinder era during the 60s, but interest in old hot rods didn't seem to really take off until the '70s as part of a general wave of '50s nostalgia. 2
stavanzer Posted August 8 Posted August 8 It is very interesting. And just as relevant if you want kit based parts rather than Resin or 3D Printed. 1
Chris V Posted August 8 Posted August 8 This other old thread elaborates further on the subject of the old AMT Trophy Series engines: AMT Trophy Series Engines On a related note, only a few of the early AMT kits included hop-up parts for the flathead engines, and only for the 1949-53 generation flatheads. However, the "Street Rods" reissue of AMT's 1940 Ford Coupé included a small additional sprue with a set of finned heads with separate water hoses. For some reason these have never been included in any subsequent reissues of the kit. Though crude by todays' standards they do offer you the option of building a hot rod with a simplistic charm that's very fitting for the old Trophy Series kits. 2
Chris V Posted August 12 Posted August 12 On 8/8/2025 at 12:42 PM, Chris V said: This other old thread elaborates further on the subject of the old AMT Trophy Series engines: AMT Trophy Series Engines On a related note, only a few of the early AMT kits included hop-up parts for the flathead engines, and only for the 1949-53 generation flatheads. However, the "Street Rods" reissue of AMT's 1940 Ford Coupé included a small additional sprue with a set of finned heads with separate water hoses. For some reason these have never been included in any subsequent reissues of the kit. Though crude by todays' standards they do offer you the option of building a hot rod with a simplistic charm that's very fitting for the old Trophy Series kits. Case in point:
stavanzer Posted September 6 Posted September 6 I've managed to get the Hemi from this series from a fellow Forum Member. Going into the '34 Ford Pickup.
