Thanks Bruce, Daniel, Kevin, David, Ray, Carl, Austin & Jonathan - yes, Vector is first!
Thanks Bill, method to my madness, as they say! LOL
Thanks Brian, Dave Van - yes, it will be also, in full detail
Thanks Ira, Frank, David, Monty, Mike, Shaun - yes, I know exactly what you mean, thanks!
Thanks Thomas, Jesse, MrObsessive, Ron, Bob & Mike - no problem, mine too!
Filler sanded and smoothed out. Front hood radiator exits crafted and attached, windscreen valance vents created, and thin over lays of fenders and hood begun.
With the basic bodywork constructed, next I'll start adding the finer detailing, like window trim, fender flares & interior :)
10155703_605434959550217_2017937351_n.jp
Edited by Jeremy Jon
Bob - for the most part I curve the styrene simply by hand, even 0.75mm will flex a great deal, and retain shape, but does take some patience to make it retain shape, the rest is by layers and filler then sanded to final shape, CA glue for the most part
Thanks Dave, Bill & Mike! :)
Adding details to front suspension; shock towers, coil spring cups, mounting brackets and bolt heads
10171859_607945942632452_1188915479_n.jp
Adding body details; chrome trim around window openings, cowl vents and "B" pillars
Continued body shaping, subtle curves of the front fenders and hood
Start of fabricating the rear engine cover, and adding detailing to body further, including gas cap
You make it look sooooo easy...but we all know is not!!! Simply said....MAGNIFICENT and SPECTACULAR work of scrachtbuilding on an equally superb automotive subject. Your superb Vector model show us what you can do...now I am also glued to this thread and amazing project.
Loving this build. Awesome work! Reminds of when I used to watch Guido from Scale Kraft doing his scratchbuilds
IIRC, Guido was working on an AMX 2/3 before he stopped producing models. I thought I had seen on his home page of his website years ago, a rough casting of the AMX 2. Too bad as he did make some fantastic stuff------things you'll NEVER see offered by any of the model manufacturers.
Thank you guys for the encouraging words, this has been a fun build, and will have further development soon, as I have some free time again & work room!
Thanks Brian, Fred, JC, Mark, Carl, Johnathan, Bruce, Brandon, MrObsessive, Mike & Buzz! :)
Fred - you're 100% right, it's a lot of work, but also a lot of enjoyment for me
Johnathan - Yes, definitely!
Brandon & MrObsessive - Please post a link for his page if you can, I also like the AMX/2 concept, perhaps after this one?
Some more pics of work done
First primer coat for build up, continued shaping of contours and subtle body shapes to make accurate
10009892_609634019130311_787533705746824
Nose has many compound curves, and interesting shapes, added head lamp covers and scribing sharp lines of front panels
10154556_609634265796953_129490380385862
Gas filler cap done, more filler to roof, and further sanding until correct shape completely
10246234_609634302463616_216999928131639
Continued work on shaping and sanding until body work is correct and accurate
1896992_609634329130280_3133634590075118
984038_609634685796911_74431993609062437
Lower front nose section being developed, with incorporated side markers, test fitment with full front suspension & steerable spindles, in place
1477467_609634849130228_3713659797128185
10004007_609635035796876_126848687246578
